Cam help.
Old May 27, 2006 | 09:29 PM
lovehammer's Avatar
Default Cam help.
alright i am getting ready to put a cam and lifter kit on my 1997 T/A. I was just wondering if anyone new anything about the Edelbrock kit. here the info on it.
Brand: Edelbrock
Product Line: Edelbrock Performer RPM Cam and Lifter Kits
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-5,500 RPM
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 218 int./218 exh.
Advertised Intake Duration: 286
Advertised Exhaust Duration: 286
Advertised Duration: 286 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Valve Lift with Factory Rocker Arm Ratio: 0.525 int./0.525 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Old May 27, 2006 | 10:36 PM
Wyoming T/A's Avatar
not a bad cam.5500 is about all a lt1 wants
