QA1 setup
I had the front shocks @ 4
The Right rear was @ 3
the Left rear was @ 2
then I tried
3 in the front
the right rear was @ 2
left rear was @ 1
Pinion angle I have at -2
Your duration isn't too low or anything so have you thought about trying a higher rocker ratio? I fixed this by going to the DA QA1s on the front. I run 6 on the compression and 1 on the rebound. This lets the nose come up fast but not come completely back down until just after the 60ft or so. It made a huge difference on consistancy and traction.
I am planning on adding a Trans Brake and new ignition system next. We will see how a two step- trans brake- N2O launch will hold next
I used to hook up with my old LT1 witn no problems
I also tried stiffer rear settings to no avile back then. have not been back to the track enogu this year to get more testing on the DAs
Ride height is stock, rear tire pressure is 19psi, fronts are 40psi. Car weighs 3400 even, with me in it. Hope this helps.
Seems to be working on that car!
I am still running stock shocks/springs and think it is doing pretty well....BUT we race at REALLY well prepared tracks.
