need info on what cam to get..
laxmad16, Uhh 315-900lbs of tourqe would require a pretty unstreetable setup and from a cam only car it's not even likely. Perhaps it was a typo? You are going to need a set of headers for a cam just for starters.
Brand: comp cams
Product Line: Competition Cams Xtreme Fuel Injected Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,800-5,800 RPM
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with 1.6 Rocker Arm Ratio: 0.570 in.
Exhaust Valve Lift with 1.6 Rocker Arm Ratio: 0.565 in.
Valve Lift with Factory 1.6 Rocker Arm Ratio: 0.570 int./0.565 exh. lift
Lobe Separation (degrees): 113
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: 268XFI HR13
also needs:
2800 stall
52mm TB
1.6 rockers
comp 918 spring
Will also make good power when upgradeing to ported heads
I ran a 222/228 .544/.538 112 dur in mine up till about a month ago
CCA-07-466-8 $245
Comp Pro-Mag 1.6 Rockers $325
918 Spring $180
Yes what I suggest is more $$$ but it is also better components.
Always remeber you get what you pay for.
CCA-07-466-8
Brand: comp cams
Then the Lt4 cam around how much more hp would i get?
The cam price is about the same.
The Pro-mags are one of the best 1.6 rockers on the market...there are some you can buy for approx $170.
The 918 springs are Comps new Beehive spring...they will hold up to the larger lift numbers.
The rockers in the hotcam kit are GMPP..not designed for heavy duty applications IMHO..also the springs will not support much more lift if you ever decide to go bigger.
Which you will if you go with the hotcam.
I just took out my 222/228 .544/.538 112 because it was not enough cam for my goal.
I am now running 246/254 .613/.590 112
