Suspension
Old May 31, 2006 | 12:05 AM
edlt1's Avatar
Default Suspension
whats the first step to take on suspension mods.
I am running low on my build cash for this summers mods, but I am thinking about squeezing in a few suspension mods.
Whats the first step?
and whats cheap?
Old May 31, 2006 | 12:14 AM
streetwarrior96's Avatar
and whats cheap?
cheap????? Well this is what I spent
Spohn Performance Adjustable Crossmember Mounted Torque Arm w/ driveshaft safty loop $450.00
BMR Fabrication Tubular Front Upper Control Arms $220.00
BMR Fabrication Tubular Front Lower Control Arms $440.00
BMR Weld In Relocation Brackets $80.00
BMR Lower Control Arms Boxed w/ Poly/Poly Bushings $150.00
BMR LT1 F-Body K-Member $500.00
BMR Front 300 LBS springs $50.00
HAL Generation "F" Series Front Adjustable Shock $180.00
HAL Generation "F" Series Adjustable Rear Shock $150.00
$2200.00 Not includeing installation. This is the more simple stuff, there is more technical stuff
Old May 31, 2006 | 12:17 AM
TAEnvy's Avatar
Most People will probably recomend Lower Control Arms and LCA reloation brackets. Supposed to make a world of difference in the launch and greatly decrease Wheel hop under acceleration.
Old May 31, 2006 | 12:33 AM
edlt1's Avatar
thanks TAEnvy
thats the advice I was looking for
Old May 31, 2006 | 12:36 AM
the_merv's Avatar
I wouldn't go through all that unles I was constantly racing it. I have an Eibach Pro kit(springs), and I am soon putting on a Strut Tower Bar. It is glued to the road with the Kit already.. The Springs only cost me $250.
Old May 31, 2006 | 09:47 AM
TAEnvy's Avatar
I wouldnt just do springs. The stock shocks are horrible and with lowering springs you will probably blow them. If you do springs, shocks are also neccesary, without a doubt, unless all you are doing is showing the car, but your not so...
If I where you I would go to the Handling and Braking forum and post a price range and goal (i.e:drag racing, auto X) and those guys in there will fix you up. They are very knowledge
Old May 31, 2006 | 09:50 AM
Honda Hunter's Avatar
From the research Ive done and based on my own mods I'd say springs, shocks, and good tires. After that relocation brackets and lca's. Then tq arm, then subframe connectors last.
Old May 31, 2006 | 09:54 AM
TAEnvy's Avatar
Honda Hunter: If you talk to most of the guys like Sam Strano they will say SFCs only corrrect the problems that a set of good shocks would cure. They say that instead of putting these on and adding weight you should just put on some good shocks and theyll do all the things that the SFCs will do.
Old May 31, 2006 | 10:01 AM
Dude, i know that. That's why I said they should be last only if youre headset on getting them. Ive gone through this argument many times after someone showed me the truth about sfc on 4th gens. Believe me, in this section everyone swears by them. I got them because Im a Mustang convertable man and thought all uni bodies were the same. I learned different after searching ls1tech.
Old May 31, 2006 | 10:46 AM
the_merv's Avatar
The LS1 Big Brakes are some good Brakes for the price of $150 area. With them, you can upgrade to the Corvette Stuff, but they aren't bad to start with.
Old May 31, 2006 | 11:04 AM
OneFast97Z's Avatar
Another vote for BMR Lower Control Arms and Relocation brackets... i would also suggest an adjustable panhard rod... then get some shocks and springs and a good set of tires... then move on and do an adjustable torque arm and safty loop, then subframes.... etc...
Old May 31, 2006 | 07:36 PM
96z28camaro's Avatar
Yah i say lcas and panhard b/c they are cheap and pretty easy to do to start off then maybe get ya a good set of shocks around. After possible spend some a littel more money and get ya a torque arm and maybe some sfcs. you could get a strut tower brace too if you wanted to they are dirt cheap anyways in fact i picked one up off the forums for 20 bucks so jsut search around and you can find some good deals.
Old May 31, 2006 | 07:41 PM
Sick99WS6's Avatar
SFCs are not worth it. Maybe if you have a vert. Go with LCAs, relocation brackets, and PHR in that order. I like the BMR stuff and the option of your color is sweet too.
