Ac Help Asap
Old May 31, 2006 | 08:41 AM
96 LT-1's Avatar
Bad Seller Warning!
Default Ac Help Asap
Ok guys im gonna start to take my AC out (condenser and lines) what do i use to plug the holes that go up to the cooler in front of the radiator?? anything else i need to know? im keeping compressor in till i lower alternator...
Old May 31, 2006 | 11:45 AM
96 LT-1's Avatar
Bad Seller Warning!
anyone????
Old May 31, 2006 | 12:57 PM
daniel6718's Avatar
to plug what holes?
Old May 31, 2006 | 01:03 PM
blind527's Avatar
The A/C lines don't go into the radiator. They go into the condensor. Just take off the radiator shield, then unbolt the lines from the firewall, and to the back of the compressor, and it just pops out.
Old May 31, 2006 | 02:44 PM
the_merv's Avatar
Veteran: Air Force
What you call the cooler is actually the Condensor. Like what was said above, remove it completely, it serves no function when the AC is removed, and it is in.
Old May 31, 2006 | 09:52 PM
96 LT-1's Avatar
Bad Seller Warning!
oh wow... i didnt know that was the condensor.... i thought it was a tranny cooler or something but what is the little silver canister then???
Old May 31, 2006 | 10:11 PM
the_merv's Avatar
Veteran: Air Force
I always called it the AC Canister, that holds some of the Freon when the system is not on.
