LT's Must be Coated??
Did you purchase your headers thru Jet Hot or did you buy them used off of the for sale section here?
If it was false, then anything I said wouldn't be true. Which, in fact, it is. The Jet Hot coating protects rust corrosion for what, 50 miles? My headers started to rust immediately, and so did many others that have them. The Jet Hot coating is not made to resist rust corrosion, no matter how much they say it does. Many of the people the buy them thinking they won't rust are in for serverly disappointing results.
This is a web forum, the whole point is to respond to what people say. Do you have anything usefull to add here? I don't appreciate people lieing and passing off their bogus info to less knowledgeable people, that creates a whole chain of wrong information.
i was told 20-30 and heard on some other websites
I am talking about the primaries themselves. Coating significantly reduces heat.
i was talking about engine bay temps, which is what i said did i not? Maybe before you bash try and understand what i said, if i didnt make sense ask...dont mean to be rude or start a fight but i said under hood temps which in my mind means an engine bay, will reduce it to 20-30 degrees
but anyway we clarified what was meant so sorry
which is where i read the information from 20-30 degrees cooler, they used a thermometer, maybe ill do a real test since my car is in pieces and see what my results are.
