OPTISPARK upgrade
Old Jun 2, 2006 | 03:56 PM
ricardo colon's Avatar
Default OPTISPARK upgrade
is there any upgrade for the optispark , is there anything that we could do to make it last longer , beside not driving the car or things to be avoided , 1994 trans am gt. JUST LOOKING FOR INFORMATION, before problems starts.
Old Jun 2, 2006 | 06:47 PM
Beast96Z's Avatar
If you stick with a GM opti, you need to upgrade to the 95+ year model that is vented. However, that won't guaruntee a problem free opti. If you would like to spend a little extra time and money you could upgrade to the billet MSD opti or the Delteq coil on cylinder ignition.
Old Jun 2, 2006 | 06:52 PM
bigredexpress99's Avatar
is this really Adv tech?.....lol. Anyways, I have heard good things form the MSD setup, I have a buddy who is getting it, just waiting for it to show up now...
Old Jun 2, 2006 | 08:24 PM
FlamingChicken's Avatar
I was able to buy a delteq setup, all new parts, for almost the same price as the msd opti. that would allow you to rid yourself of the cap and rotor.
Old Jun 2, 2006 | 08:35 PM
burnzilla's Avatar
Originally Posted by Beast96Z
If you would like to spend a little extra time and money you could upgrade to the billet MSD opti .
+1
Old Jun 2, 2006 | 08:42 PM
engineermike's Avatar
FYI I just installed an MSD cap and rotor on my stock opti. Definitely a good upgrade as it fixes the 2 main problems of the opti. It has a brass screw that holds the rotor together instead of the stock cheesy plastic rivets. Also, it adds a 5th bolt. The stock one only has 4 bolts and that allows the case to warp and let moisture in.
Old Jun 2, 2006 | 09:04 PM
TwoFast4Lv's Avatar
do a search on the Following.
LTCC
Delteq
and MSD
You will find alot of info and some bickering on what is best (I am replacing MSD with Delteq and MSD) but over all alot of good information!
Good luck!
Old Jun 2, 2006 | 09:14 PM
CULATR's Avatar
hey is there a how to on the delteq system install to a lt1 car ???
Old Jun 2, 2006 | 09:28 PM
Imports_Suck's Avatar
i had a buddy to install a coilpack system on his 95 LT1 and he had a whole lot of problems with timing.
isnt there a way to modify the block and run a regular distributor?
Old Jun 2, 2006 | 09:40 PM
1994Z28Lt1's Avatar
yeah you could run a different intake manifold or cut a hole in the existing manifold but i dont think you will be able to fit a distributor under the cowl on an f-body there is a reason why the distributor isn't back there
Old Jun 3, 2006 | 12:27 AM
NotACop97Z's Avatar
If you go to delteq's webpage they have clear insructions that you can download
Old Jun 3, 2006 | 02:52 AM
TwoFast4Lv's Avatar
The kit comes with GREAT instructions also! I was suprised and happy to see the were specific to the radiator mount kit I got
Old Jun 3, 2006 | 03:33 AM
JB_94_z's Avatar
I put a Dynaspark in my Z and it did a nice job for me.. The MSD setup would probably do well for you!
Old Jun 3, 2006 | 02:46 PM
Beast96Z's Avatar
Were doing the LTCC on a friends 97 formula right now. Were having problems with the grounds smoking out. With a direct port kit and this thing, it's almost to much clutter. Hoping he changes his mind and sells the LTCC for the MSD.
Old Jun 3, 2006 | 02:51 PM
Honda Hunter's Avatar
When will someone do a comparisom of the dynaspark and MSD?
Old Jun 3, 2006 | 03:29 PM
Steve40th's Avatar
Theres a GM engineer that ran the corvette action center for many many years, and he point blank said, before the MSD OPTI came out, to go DELTEQ as it was the only way to cure the issues with the OPTI design, then cursed the Opti and walked away. He basically was person who had to diagnose problems for GM the whole time he worked there in production vehicles, after the fact. Gordon Killebrew was his name.
Old Jun 3, 2006 | 03:37 PM
68birdls1's Avatar
another vote for delteq! great system and super easy to install. now taking the valve cover off is the only problem... just takes a little bit longer thats all lol. but a great system non-the-less
Old Jun 3, 2006 | 05:07 PM
thesoundandthefury's Avatar
Unless you install it like this:
Old Jun 12, 2006 | 03:49 PM
is there a way to seal them , like liquid electrical tape.
Old Jun 12, 2006 | 03:57 PM
lt197formula's Avatar
the new msd opti that just finally came out or i have the dynaspark and im happy
