Skinnies on a camaro
Old Jun 4, 2006 | 08:59 PM
slowmofo's Avatar
Originally Posted by smoknta
I dont see a problem running a spacer up front as long as you get longer wheel studs and use the correct lugs.
Old Jun 5, 2006 | 09:36 AM
TwoFast4Lv's Avatar
I am running Et Street Billit Wheels and one inch Bolt on spacers in the front and Bogart 15x10 Drag-on II's in the rear and did not have to touch my calipers
I HAVE seen how far you have to grind some calipers and it did not give me a warm and fuzzy What can i say since that last accednt I am a little picky on safety
Old Jun 5, 2006 | 11:30 AM
MrBill97396's Avatar
Had 15x5's ran small spacers and light grinding on the calipers never had any issues. Do not go bonkers on grinding but just enought to give a reasonable amount of clearance.
Old Jun 6, 2006 | 05:07 AM
94FBIRD's Avatar
Try Centerline Convo Pros for your front skinnies. No spacer and no grinding needed.
Old Jun 6, 2006 | 10:09 AM
blkchevyz's Avatar
i run the centerline telstars and i didnt have to run a spacer... once i changed the front pads and rotors though i did
