What do you think?
Old Jun 5, 2006 | 01:45 PM
the_merv's Avatar
Default What do you think?
This what I am building up when I get back in the States. I hope to hit the 12's, what do you guys think it will do. The only run I have made in it was when I first got it, and it ran a 13.89@100mph, and that was with only a Slowmaster that the previous owner had on it, and a K&N Air Filter, Stock Intake.
1995 Z28 Stripper A4, weighing in at 3300lbs, 3460 with me in it.
K&N Air Filter, with Custom Cold Air Induction
Hotcam, 1.6RR. stock Heads, EGR and AIR Delete, AC Delete
Pacesetter LT's, Y-pipe into Dynomax Bullet, with no Cats
Has a custom Race Tune, adjusted about everything
Redline at 6200Rpm, shifting at 6000Rpms, stock Stall
Has a programmed Shift kit at Wide Open Throttle only
3.73's, with a brand new Posi, Eibach Pro Kit, SLP Strut Tower Bar
Brand new BF Goodrich KDWS 275/40ZR17's, with 17x9.5 Z06's all around.
Old Jun 5, 2006 | 02:32 PM
infinitebird's Avatar
I think you should definitely be in the 12s with that (if you can hook).
