cc503
I would do RR, springs, retainers, locks/seats, pushrods.
CCA-614-16 Comp 10 degree +.050 locks
CCA-795-16 Comp steel retainers
ARP-134-7103 ARP 7/16" studs
CCA-26918-16 Comp 918 beehive springs
7808-16 Comp oem hardened pushrods
Speed Engineering might still have these on sale, so call em up. I'd reccomend the 918 springs over any other unless your cam lift is over 580 or so, which I doubt it will be. Get the 1.6 7/16" NSA pro mag RR and ARP 7/16" studs and the GM guideplates. Search around and you'll find all the info you'll need. And you shouldn't need new lifters, especially not the Comp R's.
