Temp Sensor
Old Jun 9, 2006 | 06:13 AM
4ced's Avatar
Default Temp Sensor
Just installed plugs and wires and a new stat... but when i switched on my temp guages wont move! i think i probably forgot to plug the temp sensor back on... which one is it and where exactly?
Old Jun 9, 2006 | 07:49 AM
the_merv's Avatar
The one that displays on the Dash is on the drivers side Head, between #1 and #3 Cylinders. If you have to take it out, some Antifreeze will come out, so do it when it's cold if you have to.
Old Jun 9, 2006 | 12:10 PM
Honda Hunter's Avatar
What merv said. May have been burnt or is faulty.
Old Jun 9, 2006 | 03:16 PM
4ced's Avatar
have to open up the CAI to get under there, which is actually quite a bitch seeing as the moroso is so tightly packed in together... or is it easily accessible from under?
Old Jun 9, 2006 | 03:21 PM
Youre thinking of the wrong sensor. The one you need to look at is where Merv described.
Old Jun 9, 2006 | 03:44 PM
the_merv's Avatar
Pretty easy to find, only thing bolted in the Head. You will burn the **** out of yourself if you feel for it while the car is still warm, let it sit for the night.
