help start my car....
Old Jun 11, 2006 | 01:12 AM
pontiacfireTAWS6's Avatar
Default help start my car....
Ive done just about everything with my car, so im not sure where to start. What are some things to look for when I turn the key, my lights dim and then get brighter. It is a brand new battery, the motor does not do anything, no cranking no sound of a starter. What should I check and double check?
Old Jun 11, 2006 | 01:19 AM
rob97TA's Avatar
I would check the wiring to the starter, and if everything checks out there, take the starter off and have it checked.
Old Jun 11, 2006 | 01:22 AM
I did the Wire mod routed under in the wheel well, Im pretty sure the starter is OK, unless it can go bad sitting for a few months? I also re-located the battery..
Old Jun 11, 2006 | 01:33 AM
On the passengers side wiring, There are two wires with solderless conectors on them... one is yellow and one is duel black with white stripes going down them.... Do these go to 12V power or to ground?
Old Jun 11, 2006 | 01:37 AM
I Also did Fan switch... new waterpump, hooked up nitrous, new opti cap and rotor.......new steering column... air bag delete..I think thats about it with electric changes...
Old Jun 11, 2006 | 03:56 AM
Blown_Red_97z's Avatar
damn with all of that who knows where to start? try smacking the starter. thats a joke really, dont do that, so there is no clicking sound or anything?
Old Jun 11, 2006 | 01:12 PM
ellokote5's Avatar
check the battery's voltage, if it is correct then check that all wires are tight
Old Jun 11, 2006 | 02:27 PM
harvickgm's Avatar
check the voltage at the starter with the cable hooked up. if your getting 11.6 volts or higher you should be fine. now if thats ok, check the voltage at the purple wire the starter relay wire while trying to crank it.. you should have close to 12v on that, if not there is a problem with that wire. did you relocate the battery to the back and if so what gauge batter wire did you use to wire it with???
