Volt Drop On De-acceleration
Old Jun 13, 2006 | 04:02 PM
97BLACKBULLIT's Avatar
Default Volt Drop On De-acceleration
when the rpm's drop from hitting it the lights flicker for a second and it seems like the whole car loses electric power for a split second. any ideas on the problem?
all the connections to the battery and alternator seem good.
Old Jun 13, 2006 | 04:31 PM
dhdenney's Avatar
Are you running an underdrive pulley?
Old Jun 13, 2006 | 05:35 PM
Predator T/A's Avatar
do a volt drop test on the system
Old Jun 13, 2006 | 07:30 PM
P97LT106's Avatar
voltage regulator in the alternator, change it and see what happens, if it doesn't fix it, take it back
Old Jun 14, 2006 | 07:02 AM
thanks for the replys. this is just something i never seen before.
Old Jun 14, 2006 | 08:17 AM
IllusionalTA's Avatar
belt might be slipping
EDIT: Decel eh? Possible loose connection? that's what the flicker sounds like..
