Collector Gaskets and Bolts
Old Jun 14, 2006 | 11:32 PM
BizZzatch350's Avatar
Moderator
Default Collector Gaskets and Bolts
What are you guys using for the collector gaskets and bolts? Its a 3/8 bolt right? So a set of 3/8 bolts for collectors and a 3 inch collector gasket is what I need? Looking at this set up from Summit, part # BIG-10025FLT
Old Jun 15, 2006 | 08:32 AM
lt197formula's Avatar
Mine came with my hooker lts but yes im pretty sure they are 3/8 inch bolts and yes just 3 inch collector gaskets.
Old Jun 15, 2006 | 08:35 AM
Tony Shepherd's Avatar
I always used the 3" Felpro gaskets and 3/8 bolts. Then double nutted them so they will not vibrate loose.
Old Jun 15, 2006 | 08:50 AM
96formvert's Avatar
I've been told that the percy soft aluminum gaskets were some of the best...I got some for my header and collector.You can get em at autozone, summit, or jegs.
Old Jun 15, 2006 | 10:21 AM
roughneck427's Avatar
I use 3/8 bolts and lock nuts and NAPA has 3" collector gaskets that have a lead type coating on them great gasket if they start to leak just tighten them they never blow out
Old Jun 15, 2006 | 05:46 PM
Moderator
Summit wanted some 10$ handling fee, no thanks to that. Alright, well I'll pick up the Y tonight, so I'll have to order the collector stuff as well as what ever I may need for the Borla
