morel lifters
Old Jun 15, 2006 | 08:49 PM
Juicedz's Avatar
Default morel lifters
has anyone dyno tested morels? I have mine set at .030 preload, an it seems as if I'm getting valve float around 6600 rpm? Thr car peaks just under 6600, then dramtically falls off by about 30hp at 6800 then picks up again. Alos, if I have valve flaot, would my a/f be affected? I'm running comp beehive springs.
Old Jun 16, 2006 | 10:00 AM
IllusionalTA's Avatar
From what i was told about the morel's..They're a great quality lifter, but they're heavy, and will carry more weight over the nose, i.e might need to use more spring to control the valve.. Give bret, a call and see what he say's about it..
Old Jun 16, 2006 | 01:27 PM
Juicedz's Avatar
when Lloyd ported the heads, he installed the springs, or one of his engine builders. He knew what the cam would be when the springs were chosen
Old Jun 16, 2006 | 03:06 PM
well cam yes.. but did he take into account the added weight of the lifter? just curious. it very well could be somthing else.. just throwing out idea's..
Old Jun 16, 2006 | 03:20 PM
Juicedz's Avatar
is there a big weight difference brtween morels-comp r's- oem?
Old Jun 16, 2006 | 09:57 PM
TwoFast4Lv's Avatar
I love my Morel's. Set at .025 pre-load she rev's clean to 7,200 with K-Motion springs and 2.055 valves
Old Jun 17, 2006 | 12:08 PM
Juicedz's Avatar
twofast4lv, did you play aroubnd with the valves on the dyno to see where they made most power? Are there any disadvantages of running close to zero lash other than a much louder valvetrain?
Old Jun 17, 2006 | 01:37 PM
TwoFast4Lv's Avatar
I did not want to run Zero lash. makes more power for many but I have never been a fan of being on the verge of to much lash with Hydro's. My Valve train is really quiet now. Much better then with the Comp "R"s or OEM style lifters. If it were not for the car shaking and a give away idle you would not know what was about to hit you
BTW the Morels did not really seem to be to much heavier then the Comp "R"s I took out.
Old Jun 18, 2006 | 01:53 PM
Juicedz's Avatar
so will running less lash hurt the valvetrain afteer time?
Old Jun 18, 2006 | 06:09 PM
flyinZ's Avatar
What do those Morel's cost? Where to purchase them??
Old Jun 18, 2006 | 08:16 PM
about 400 and some change.. thunder has them, as well as a few other's..
Old Jun 18, 2006 | 11:47 PM
asudecat's Avatar
I just set mine alittle more than 1/2 turn past 0 lash.
Should I just set them at 1/2 past 0 lash?
Start up will be next couple of days.
