new camaro problems
Old Jun 16, 2006 | 08:44 PM
Chris18927's Avatar
Default new camaro problems
i just got my 94 z28 today and i gots 2 problems. 1. the a/c is broke. i thought i just needed some r134a but i hooked the can up to the a/c and it didnt take any of it. it blows air but its hot so i have no idea. need help quick im in florida and its hot! 2. the red light in my tach is on that looks like a low fluid level light, its a red box with little watter ripples that are close to the bottm of the box. what is that and how can i make it go away? thanks
Old Jun 16, 2006 | 09:03 PM
396D1SS's Avatar
on the ac part check your vacuum lines real good. what part of fla?
Old Jun 16, 2006 | 09:27 PM
Chris18927's Avatar
orlando
Old Jun 16, 2006 | 09:43 PM
396D1SS's Avatar
i am about 25 miles south BTW check your coolent
Old Jun 16, 2006 | 10:36 PM
Chris18927's Avatar
yea my coolent is full but its rusty lookin so i think i might have 2 flush it
Old Jun 16, 2006 | 11:02 PM
94Z28Joe's Avatar
your check engine light will not be on for a/c code but it will stop your a/c from working if there's a code for a/c. also check to make sure your pressure switch is good and the harness going into the compressor is good.
Old Jun 16, 2006 | 11:03 PM
ex-SS-ve's Avatar
new thermostat. just to be safe, coolant flush. bleed the hell out of it. and youll be ok. now for the a/c just check your fuses to be sure the a/c clutch fuse isnt blown
Old Jun 17, 2006 | 09:04 AM
Low N Slow's Avatar
You need to jump the low pressure switch to make it take freon if it's too low. Just unhook the connector and jump between the 2 terminals on the connector.
Old Jun 17, 2006 | 12:23 PM
02NITROUSLS1's Avatar
The switch has three terminals not two.
Old Jun 17, 2006 | 12:47 PM
Camaro Fan's Avatar
Don't these cars only have the high pressure switch, 3 prong up on the small diameter line beneath the low side filling port? Is there another switch?
The light you describe sounds like the low-coolant light, which is prone to false readings. If you look on shoebox's sight (http://shbox.com/1/low_coolant2.jpg) he has info on it's location and removal, if that is indeed the culprit and the coolant is not low you can try removing and cleaning it, replacing it, or merely unplugging it to get rid of the light.
Old Jun 17, 2006 | 08:53 PM
Chris18927's Avatar
i found the problem its the connection to the ac clutch was falty so i fix it
