At what point should u have an LT4 KM
Old Jun 17, 2006 | 12:26 AM
LS1Silverado05's Avatar
Default At what point should u have an LT4 KM
At what point does an LT4 KM become a good idea? Right off the bat or is there a mod in particular that makes it necessary?
Old Jun 17, 2006 | 12:30 AM
burnzilla's Avatar
When you get headers, the LT4 Hotcam kit is superb.
With mids or LT's, you can easily expect 35-40 hp from the HOTcam kit and headers/Ypipe.
That and a stall, and you got yourself a ****** competitor.
Who says this with such authority? I tell you... his name is Cap,...... Captain Morgan
Old Jun 17, 2006 | 12:42 AM
TV559's Avatar
I think LS1Silverado05 is talking about the LT4 Knock module. If so I think it would be a good idea after you install mods such as: long tube headers, Roller Rockers and a loud exhaust. Or you can do it for the hell of it cause it's a cheap mod.
Old Jun 17, 2006 | 12:47 AM
mthegodfather's Avatar
Right of the bat. Good cheap mod.
Old Jun 17, 2006 | 01:49 AM
Any real risk to running an LT4KM in an LT1 setup? Meaning will it ignore potentially harmfull signals?
Old Jun 17, 2006 | 01:13 PM
burnzilla's Avatar
I asked this on LS1LT1.com, because I know a couple of the guys there.
You can't just change the Rockers and Cam, its will cause serious valvetrain failure.
You need the appropriate springs, lifters and rockers to go with the cam.
Thats why it comes in a kit for $530.
Old Jun 17, 2006 | 01:34 PM
Ls1Bait's Avatar
Where can i get a LT4 Knock module for my junk. Guess i could use one.
Old Jun 17, 2006 | 01:39 PM
TwoFast4Lv's Avatar
Actually if you can program there is no need at all
Old Jun 17, 2006 | 05:13 PM
steez's Avatar
.....hmmm Explain?
Old Jun 17, 2006 | 05:26 PM
burnzilla's Avatar
Wow, your talking about a knock module.
Ill just STFU now.
Old Jun 17, 2006 | 05:37 PM
urbanhunter44's Avatar
You can get it online (gmpartsdirect.com) for like 30 bucks. Or program your computer to reduce knock sensitivity.
It's a good mod after LT headers. I noticed a SOTP difference, and also observed my knock count via brick scanner. It went to 0 after the LT4 KM install.
Old Jun 18, 2006 | 01:55 PM
steez's Avatar
i heard it can cause some serrious problems though...is that true?
Old Jun 18, 2006 | 03:25 PM
91Z28's Avatar
I think many re-use the stock lifters with no issues. You are dead on about the springs though.
Old Jun 18, 2006 | 10:52 PM
ToxicTA's Avatar
The LT4 Knock Module is just a better quality noise filter. If you add roller rockers or any type of mod that may increase noise it is recommended to either run the LT4 module or adjust the tune to prevent timing retard. I have not heard of anyone having any type of damage caused because they installed a LT4 knock module the worst I have heard was there was no increased performance and that would be because they weren't having any knock retard in the first place.
Old Jun 18, 2006 | 11:49 PM
Why the hell would roller rockers add noise? I would think it would be less?? Are you saying if the ratio is increased that the valves are snapping harder and thats why?
Old Jun 19, 2006 | 07:50 AM
ToxicTA's Avatar
One of the differences between the LT1 and The LT4 was the addition of roller rockers. As I stated before the LT4 Module is just a noise filter nothing more. If you are running mods that increase noise than you will want to run a LT4 Module or a tune to account for the additional noise unless you want to run your timing retarded.
Old Jun 19, 2006 | 09:01 AM
Honda Hunter's Avatar
Waste of money I think. Just get it done through the tune.
Old Jun 19, 2006 | 10:38 AM
tfs95z28's Avatar
short of hooking up a scanner is there a way to find out if you have false knock? Also if you have had the pcm reprogrammed because of the Hot cam kit, would they have "desensitized" it to not detect it automatically?
Old Jun 19, 2006 | 06:26 PM
sdm1234's Avatar
with the addition of rollers comes the addition of noise, whether or not you insrease the ratio. the bearings and roller tips cause it. it's easily noticable to knock sensor, believe it or not.
