Hooker gave cruise cable burns in a bad way
Old Jun 17, 2006 | 05:45 PM
BizZzatch350's Avatar
Moderator
Default Hooker gave cruise cable burns in a bad way
The slip fit from my Hookers LTs and cruise control cable decided to get togther, think the primary from the LT gave it an STD because it burned it prety good. Not sure if it works any more, but I ended up moving the cable out of the way and hoping it stays away. If the cables a gonner, is it prety easy to just swap the cable out?
Old Jun 21, 2006 | 11:06 PM
FIREHAWK #07's Avatar
lol same **** happened to me!!! eventhough i can see the inside of the cable; it still works!! I use the cruise control eveyday going to work and back !!!
Old Jun 21, 2006 | 11:34 PM
Moderator
You just move it out of the way?
Old Jun 22, 2006 | 02:42 AM
DeltaT's Avatar
Sounds like some drunken times I had in the military over in Korea!
Jim
PS That cable is easy to swap out.
Old Jun 22, 2006 | 05:16 AM
contraststriker's Avatar
exact same scenario here too--the header doesn't melt a steel cable so easily
Old Jun 22, 2006 | 11:11 PM
yup.. just moved it outta the way...
Another thing that got burned.... was my brake line!!! The removeable primary was rubbing against a steel brake line......!!!! So after a few weeks, on my way home from work i push on the brakes and my brake line comes on!! That scared the **** outtta me!!!
Old Jun 22, 2006 | 11:30 PM
Moderator
Mines wont run but that bitch is damn close
