.600+ Lift on a DD?
Old Jun 21, 2006 | 11:15 PM
Speed Density's Avatar
hashtagBMW
Default .600+ Lift on a DD?
Ive been searching for a good set of heads and thinking about cams too.
But i always stop looking at flow numbers after .600
Like when i look at heads I stop looking at them if they still flow very well after .600 becuase i dont think im going to be up that high.
What do you guys think about Higher lift on DDs?
Do you think .600 is ***** and i should be up higher?
Old Jun 21, 2006 | 11:24 PM
GTP PWR's Avatar
I have well over a .600. I havent tested my car on the road yet...
I know some very few people with higher lifts that drive it everyday. I dont see a problem with it.
Old Jun 21, 2006 | 11:53 PM
ToxicTA's Avatar
.590 lift with 1059 miles on my new 383 and my plan is to drive it everyday. The car performs awesome so far and have yet to exceed 5500 rpm waiting for 1500 miles and then change the rev limiter pill to 6500 and run that for a while before I run the 240 HP shot of fogger NOS. This cam would have also worked well in a 355 cid.
Old Jun 22, 2006 | 12:47 AM
TwoFast4Lv's Avatar
will be fine for say 10k miles or until it starts to smoke. The problem is worn out Valve guides and springs
Damn I think my car got 6 miles before it hit the rev limiter the first time
Old Jun 22, 2006 | 12:54 AM
hashtagBMW
So pretty much .600 isnt for a DD.
I better start looking for smaller heads.
Old Jun 22, 2006 | 02:39 AM
DeltaT's Avatar
.590 net lift on my 383 and it has 7K on it now without an additional lash adjustment. It's a Vortech-blown 383 and I run an entire Comp Cams valvetrain on it. Used an adjustable pushrod to determine the right pushrod length. Came out a perfect sweep across the valvestem.
If you do everything right I don't see why .630" - .650" isn't doable, but might need more frequent adjustments.
Jim
Old Jun 22, 2006 | 08:30 AM
SStrokerAce's Avatar
LS1 guys do it and i've done it on LT1's all the time as well.
Bret
