powerdyne
and does this kit come with everything I need like should I change injectors or anything else........
IMHO 6psi isnt really worth it either though. Especially without intercooling.
I didnt run 4.5psi for very long at all, but it was barely noticeable.
Here's the deal on 'Other' items needed... The powerdyne kits come with an FMU, throw it away or sell it and buy some SVO 42# injectors. The kits also come with an inline Walbro 255lph pump thats supposed to act as a booster pump to provide suplemental fuel volume and pressure... Dont bother putting it in, just get an in-tank 255lph pump and keep your fuel filter.
You'll def need an ignition upgrade as well, but I believe the 6psi kit come with an MSD box anyway.
Make sure you get a good tune to run the blower with those injectors, or you will damage the motor.
The FMU would give me a diff fuel pressure at 6psi boost every time I pulled through the rpm range. I expected to see this some, as its known that FMU's are inacurrate.. But on the dyno it went incredibly rich one run, then so lean it started detonating on the next run. After a cooldown we pulled her one more time and got a close to perfect A/F ratio.
The amount of variance from run to run scared me right into bigger injectors and a custom tune. Bye Bye FMU
Yes, adding boost to any motor will shorten its lifespan, but adding boost CORRECTLY can reduce the hit in lifespan dramatically. Installing the 42# injectors didnt cost me much more than those SVO 24's would have, and I got rid of the inconsistent FMU.
Plus, changing injectors is a mod that requires custom tuning. Otherwise your pcm will not be able to adjust fueling correctly. I guess something within 2# of your stock injector flow wouldnt be as noticeable a diff as almost double the flow. But it for sure wouldnt be as efficient as it could be.
FWIW, I ran the Powerdyne untill it broke at 45K miles... Then I bought the Procharger and made 100 more HP with 2 more psi and intercooling. My motor lasted another 7-8K miles before a piston ring finally gave out. No signs of detonation anywhere.
If setup and tuned properly, these motors can survive boost for a long time. Or you can do it the cheap way use an FMU without any tuning and blow it up really short of what your engines lifespan can be.
ProCharger
IMO, the 4.5 PSI aint too bad, if you have a good running motor, and just want a nice boost in power w/o having to change any internals.
Anything more than 5 PSI on an LT1 isnt recommend anyways, so in that respect, its a nice little kit.
Just my .02
