header gasket
Old Jun 23, 2006 | 01:37 AM
chameleongreen97ta's Avatar
Default header gasket
tightened down all of the bolts on my passenger side header and it still has a huge leak so time to replace the gasket what is a good gasket that is still relatively cheap something around $50 got pacesetter longtubes
Old Jun 23, 2006 | 01:51 AM
94z28L's Avatar
go with a set of mr gasket ultra seals, did the trick for me and runs perfect now
Old Jun 23, 2006 | 02:17 AM
Sgt. Spuds's Avatar
Shirley Temple Drinker
I got felpros
Old Jun 23, 2006 | 10:07 AM
96formvert's Avatar
percy's soft aluminum header gaskets. They are $30 something dollars and have a lifetime warranty. I've heard from several people they are the best and never blow out. You can get em at autozone, summit or jegs.
You want the d port ones for the lt1
Old Jun 23, 2006 | 12:58 PM
the_merv's Avatar
Is it better if you use the High-Temp Copper sealant with them?
