Which is the easiest way to remove the LT1, Top or bottom?
EDIT:
we are ready to pull it out of the top, all the accesories are off. my dad and I are slightly mechanically inclined and we did it, with no prior experience. it took a long *** time, but since we didnt have a lift, it was our only choice.
all in all, not so bad, just time consuming because of all the pioneering costs associated with such a thing.
Breeching the brake system is the biggest reason why out the bottom is a PITA.
So, I bought $30 worth of brake lines at O'Reilly's and replumbed the front brakes out of the K-Member.
It's so much easier to get it out the bottom ...
why are you guys having to drain the PS system?
if so, the bottom's the only way to go.. I did it during my 6spd/cam swap.
I just thought that bolting the motor/tranny together on the ground was SOO much easier than in the car, on top of that.
holding the front of the car up with the engine hoist and nothing more than a heavy duty 4-wheeled cart with caster's, I pulled mine out on my own.
I stripped everything off my motor (down to the long block) and cleaned/painted everything, bolting the power steering pump on in front of you is a breeze, as well as the A/C compressor AND LINES!
oh BTW, how about bolting a set of LT headers and routing your plug wires THE WAY YOU WANT all in front of you, where you can walk all the way around the motor to do it? then sliding it all in from under neath. I think that's what decided the winner to me. so what if you have to bleed the brakes, hell, it's a good idea every once in a while to do so anyway.
+1 for going from the bottom
If I'm just going to pull the motor, I'd do it out the top. This last time I also added Eibachs/Bilsteins & LS1 front spindles... so it made sense to drop it out the bottom.
To move around the whole assembly (motor/trans/subframe/struts/wheels), I installed my strut tower brace and used the engine hoist. Made moving it around very easy. All using the Happy Hooker (and those 4 itty bitty bolts
definately makes pulling the engine easier Drain the Tranny Fluid, pull the Driveshaft, unhook sensors from the motor undo the six K-member bolts and drop the tranny and motor leaving all the suspension all in tack. Drop it onto the Front wheels that way you can move it around still. Taking the A-arms off is just more hassle and you'll have to get it aligned again.
