real slow after trans installation
Old Jun 25, 2006 | 04:38 PM
pugads650's Avatar
Default real slow after trans installation
i just finished installing the transmission in my 95 z28 auto and its extremly slow in all forward gears but works great in reverse could it be beacuse i cut the exhaust off at the headers it feels like it lost 100 hp but if i give it 1/4 throttle in reverse it will sqeel the tires.
jonathan
i used the old torque converter that came with the original transmission could this be causing it
Old Jun 25, 2006 | 04:39 PM
pugads650's Avatar
i just finished installing the exhaust and it still really slow only what coud be causing this transmission or torque converter
could one of the electrical connection be causing this beacuse my speedo is not working either and the abs light is on to.
jonathan
Old Jun 25, 2006 | 05:06 PM
dhdenney's Avatar
Could have lost a bunch of low end torque. This is a truck after all. Run your full exhaust and see what happens. Did you make sure the front pump was engaged when you reinstalled the tranny? Maybe your torque convertor is shot cuz of a disengaged front pump and the disks aren't turning. IDK, just guessing......
Old Jun 25, 2006 | 05:29 PM
pugads650's Avatar
yeah this is a truck i just put it as a z28 beacuse its the same tranny and converter and i couldnt get an answer anywhere else.
anyways the converter im using has over 185000 miles on it.
I drained some of the oil by turning upside down for a couple days i got about 3 quarts out of it and added 2 quarts of new oil but it still runs like ****.
ohh and my speedo wont work i have a abs light on the dash could this be a loose connection.
how much does a converter go for thanks.
jonathan
Old Jun 25, 2006 | 05:31 PM
pugads650's Avatar
what do you mean by front pump
Old Jun 25, 2006 | 05:44 PM
mike1500's Avatar
sounds like somth ings fucked up in there, dont re use 185k mile parts
Old Jun 25, 2006 | 08:24 PM
jd783's Avatar
you never reuse a T/C when doing a reboulid all that metal that was in your tranny went in your converter also and now is back in your new tranny
Old Jun 25, 2006 | 08:33 PM
pugads650's Avatar
ive only driven it around the block a couple of times do you think the trans is ok im going to have my mech install a new tq converter tommorow i hope thats the problem.
also does anybody know where i can get a cheap tq converter here in sothern california thanks.
jonathan
Old Jun 26, 2006 | 12:12 AM
pugads650's Avatar
could it be an electrical problem beacuse i have a abs light and my speedo is not working thanks.
jonathan
Old Jun 26, 2006 | 11:06 AM
pugads650's Avatar
i cant get the round green plug in all the way could this be causing the problem this plug is located on the right side of the transmission.
