2000GTP | 06-29-2006 08:26 PM | Throttle body wont open all the way during WOT A problem I am having is that when I floor the accelerator pedal, the throttle body will not open all the way. This is definitely a hindrance with my nitrous system that has the WOT switch because the throttle plates are opening enough to engage the switch. I looked around the pedal area for obvious intrusions that could prevent the pedal from fully being depressed and I couldn't find anything out of the ordinary. Is it possible that the throttle cables are out of adjustment? Is there a procedure to tighten them up if that is the case? Or is there something else I may be overlooking? Also, the car does have TCS if that is of any issue. |
