LTCC install on 93 Z28
Old Jul 1, 2006 | 08:22 PM
Cannons's Avatar
Default LTCC install on 93 Z28
Anyone have a wiring diagram that shows exactly where the white wire goes? I hooked the pink wires to the pink wire that fed the coil, and the whire wire to the white wire that was pludded into the module. The green light is intermittantly blinking and the engine idles rough. It has a bad stumble/hesitation to it also. If the engine at least fires and runs does that mean I at least have everything plugged in properly?
OK, Nevermind on that, a better grounding solved that issue.
However, I still have an issue of no Tach! The tach is not showing any RPM's...
Old Jul 1, 2006 | 09:32 PM
harvickgm's Avatar
go to this link... this site is for 93's... any questions you have we all can answer here...
this link is for the LTCC diagram that you wanted...
http://speeddensity.org/showthread.php?t=2068
