Fuel pump Install Trap door help
Like i would not buy your car because you cut a hole to do this.
I will cut that panel in anytime over dropping the tank. A little Dremel, a steady hand, and a Fire Extinguisher incase **** gets a little spicy got the job done. You're talking some hours with dropping the tank...
