What size bolt do I need?
Old Jul 8, 2006 | 08:37 PM
porksoda's Avatar
Default What size bolt do I need?
Alright I have a big exhaust leak because one of my header bolts came out! I have Mac Mids so what size bolt do I need to replace it with? My car sound like a tractor!
Also what do you guys use to tighten the bolts with? I tried using a regular ratchet and socket but it just wouldnt fit on snug, it kind of tightened them but they could use a little more.
Old Jul 9, 2006 | 12:29 AM
FlamingChicken's Avatar
i dont remember the size but autozone carries header bolts. just tell them the info and they can pull them. depending on how thick your header flange is you may need a 1" long bolt. i believe the stock are 3/4". check your gasket to see if youve burned through it as well.
Old Jul 9, 2006 | 03:17 PM
porksoda's Avatar
One last problem. I replaced the bolt and used a gear wrench to tighten the rest. But whoever installed the headers stripped out the hole on the very back passenger side. So what do I do about that? Do I have to re-thread the hole and put a bigger bolt in it like from Lowes or Home Depot?
Old Jul 9, 2006 | 04:15 PM
Black1997T/A's Avatar
You need to use a Heli-coil kit to repair the threads. Might be kind of tricky to perform that kind of surgury in that area. You can do it with a little bit of patience,
