Few electric WP questions
Also I have a 30 amp relay that I'm going to be using, does anybody know of a closest means for a 12v trigger? I'd hate to run wires all the way into the damn interior for a trigger, I'm just not to familiar with the wiring options on the LT1.
Thanks,
Billy
This is the wiring diagram I used (made by Andrew @ AKMcables.com, if I'm not mistaken), though I deviated slightly in order to install an illuminated switch in addition to the two warning LEDs. It works well.
This is a generic diagram I cooked up of the waterpump inlets/outlets. If you're referring to the bottom passenger side, that would be the waterpump outlet / heater inlet hose. If you're referring to the bottom driver's side, that typically goes to the oil cooler on Fbodies (if equipped), then straight to the driver's side radiator. I know that the Y-body pumps don't even have a fitting in this location, so you can most likely block that off without any detrimental effects... or you could just buy the 'vette pump.
{edit} Fixed the links...
