How do Cam bushings work?
Old Jul 17, 2006 | 03:35 PM
James Montigny's Avatar
Default How do Cam bushings work?
I was advised to use "cam bushings" to compensate for my cam being 6* advanced.
I know what they look like from the summitracing pics, but I don't understand
how they work. I don't see 3 boltholes, it looks like a single funky off-center
hole. And it needs a drillbit?
I'm lost.
Old Jul 17, 2006 | 04:10 PM
Old SStroker's Avatar
I'm lost.
If the cam dowel pin is .250 diameter, so is the "funky" or offset hole in the bushing. If you drill out the the dowel pin hole in the cam sprocket to the outside diameter of the bushing, you can then advance or retard the cam by locating the offset hole in the bushings one way or the other.
If the dowel pin is on a .580 radius, each degree is just about .010, so a 4 degree offset bushing would have the .250 hole offset about .040. A bushing kit might have a 6 degree offset bushing, a 4 degree, a 2 degree and a zero degree (concentric) bushing so you could install the cam 6 deg. advanced, 4 deg advanced, 2 deg. advanced, straight up, 2 deg. retarded and 4 deg. and 6 deg retarded depending on which bushing you used and what direction you put it in.
If this is an LT1 with Opti you might want to check what happens to the ignition timing with offsetting the cam.
Clear as mud?
Old Jul 17, 2006 | 10:29 PM
ToxicTA's Avatar
Are you getting the 6* advance from a degree wheel or is the cam being advertised to have the 6* advance designed into it.
Old Jul 18, 2006 | 07:24 AM
From the degree wheel, it's suposed to be 0* (LE1HL)
Old Jul 18, 2006 | 07:26 AM
Originally Posted by Old SStroker
Clear as mud?
Makes sense, I have a feeling I have some tuning to do to compensate
if I use the bushing to fix the timing issue.
Thanks
Old Jul 18, 2006 | 09:38 AM
ToxicTA's Avatar
This is just off the top of my head and anybody feel free to correct me but in my case I have a Lingenfelter Spec'd Mechanical Roller cam and the cam is ground I believe 4* advanced just to keep you from having to use any type of after market button.
Old Jul 25, 2006 | 06:28 AM
I saw a note in Comp's install manual that said everything is ground 4* advance
to make it more usable in street applications. *shrug*
I was told to degree it to 0*, so I did
Runs great
