best build for LT1???
Old Jul 31, 2006 | 04:44 PM
slowmofo's Avatar
Originally Posted by ls1charged
hey, i heard u got a new car, looks good in your sig.
yeah, miss the ole camaro though.
Old Aug 1, 2006 | 01:51 PM
LT1MAN's Avatar
i bet you do miss that camaro, i checked it out and it was bad ***.
ok, advandced induction is going to port my heads and give me a cam, so
if i get this 383 rotating assembly:
http://store.summitracing.com/partde...5&autoview=sku
what else will i need to rebuild the engine?
Old Aug 1, 2006 | 01:54 PM
ls1charged's Avatar
your going to want to upgrade the valvetrain, (springs, retainers,locks,etc.),cam bearings, timing set,lifters,hardened pushrods,etc. im sure theres more im forgeting, but somebody will think of something else.
Old Aug 1, 2006 | 02:30 PM
LT1MAN's Avatar
thats all replaced when they do the headwork. $1600 for porting my stock heads and refurbishing them, and a new cam.
plus $9xx for the rotating assembly, thats $2500. if thats all i need to do the motor i might be able to afford this deal. ill be doing most of the labor with a couple of guys who know what they are doing. that leaves me probably $2000 for a rear end or to rebuild mine.
thats my next question, i want to run a 4:10 gear and hopefully be able to get some traction still, what kind of rear end should i get or can i beef my my 10 bolt? do i need better axles?
and my transmission was just replaced about 10K miles ago with a new refurbished t-56
Old Aug 1, 2006 | 02:44 PM
slowmofo's Avatar
m6 + 10 bolt + 4.10 =
If it was a uto you might get away with it. But If your makeing any power you will gernade the 7.5
Might see if you can find a used 12 bolt, or save alittle more for one. 2k is about the cost for one I believe
Old Aug 1, 2006 | 02:58 PM
LT1MAN's Avatar
well i definately dont want
what about the fuel system, i will surely need injectors and a pump right? what size?
Old Aug 1, 2006 | 03:08 PM
LT1MAN's Avatar
and for the rear end do i just buy a whole deal the housing and everything or just a new diff or what?
Old Aug 1, 2006 | 06:25 PM
aggiez28's Avatar
check out the 396 for sale in my sig. the entire motor is out of your budget but i could do the bottom end in your budget
pm me if interested
brook
Old Aug 1, 2006 | 08:27 PM
LT1MAN's Avatar
do you still have the heads?
Old Aug 1, 2006 | 09:07 PM
formula355LT1's Avatar
well, look at my sig but it cost me around $10,000 with labor.
Old Aug 2, 2006 | 01:16 PM
LT1MAN's Avatar
thats more than i can spend. did you buy the motor from them? what cost so much?
im lookin at $700-$1000 for a rotating assembly, $1600 for heads and cam, $2000 for rear end, not sure how much its going to cost to get the block bored, plus $500ish worth of labor that i cant do myself (internals).
Old Aug 2, 2006 | 01:54 PM
  #32
ls1charged's Avatar
when i checked to see how much it was to do pretty much the same thing that your doing it was more then just $500 bucks.
Old Aug 2, 2006 | 02:01 PM
  #33
LT1MAN's Avatar
its a close friend of mine who owes me a favor, and its just for breaking down the engine and installing the new rotating assembly. im budgeting $500 to $1000 for labor, if it exceeds that then well.....ill just have to get more money
Old Aug 2, 2006 | 04:20 PM
  #34
LT1BRN's Avatar
Originally Posted by Imports_Suck
5000 should be enough, but you always have to add in extra money for stuff you dont plan on fixing or buying.
I'm in the last days of my build up and we are getting ready to fire her up in the next 2-3 days, I am going through this crap every day, I am ruining around buying stupid parts that I thought would be in perfect ruining shape, and all that is sucking a good amount of cash, just keep the dealers hot line handy if your doing a build up.
I think so far the only 2 things I haven't changed are the fuel tank and the rear end.
Old Aug 2, 2006 | 05:41 PM
  #35
ls1charged's Avatar
thats alwys nice. just remember to add a little extra cash on to your project for little things like mentioned above. it seems like that happens to everyone, it can never be a smooth process, theres always something that goes wrong or something u forget.
Old Aug 2, 2006 | 06:17 PM
  #36
Built LT1's Avatar
Originally Posted by TAdriven98
5,000 I would think 383 or better yet 396. Check out Golens they have some good prices and packages, a 396 with killer heads and cam combo would be an awesome street/strip car.
After two LT1 build ups, Golen may not be a bad idea.
Old Aug 2, 2006 | 06:27 PM
  #37
Well if I put the price down for every thing by itself thats how much $ u would be spending i bought everything through them when i sent the car in it was bone stock, the longblock with the ported heads cam and all the good **** was like $7500 with labor.+8.75%tax(almost a grand there), converter, frameties,e-waterpump,LT's,cai,fuel pump and all the other crap it was more than 10grand. Just do as much as u can yourself and save alot of $ on the labor. But i definately think u'll need more than 5grand. IMO good luck
Old Aug 2, 2006 | 09:20 PM
  #38
ls1charged's Avatar
do they have a web site?
Old Aug 3, 2006 | 07:06 AM
  #39
LT1MAN's Avatar
definately.
Old Aug 3, 2006 | 07:12 AM
  #40
LT1MAN's Avatar
is my 2 bolt main block going to hold up for this setup? is there some kind of super special bolts i can get to strengthen it?
