white face gauges
Old Aug 8, 2006 | 09:25 AM
subhumanzz's Avatar
Default white face gauges
does anyone know how to remove the dash pad to get to the gauge cluster? i dont see how the damn thing comes off of there!
Old Aug 8, 2006 | 09:49 AM
96lt1m6's Avatar
be gentle with the upper dash and remove it by lifting it up easy at the ends working your way to the middle it is heald in by plastic push in studs and they will break if you are to aggressive while being careful lifting cause you can also break the dash cover(crack)after it is removed you will notice (2) 7mm screws on top of the cluster bezel.......remember this panel is old now and the sun has taken its toll on the plastic making it brittle.
Old Aug 8, 2006 | 11:12 AM
subhumanzz's Avatar
cant seem to find anything on line. know of any pics on shoebox or anywhere else? i cant seem to find anything!
Old Aug 8, 2006 | 12:35 PM
subhumanzz's Avatar
Old Aug 8, 2006 | 12:42 PM
96lt1m6's Avatar
re-read post #2 that will be all you need to get the job done
Old Aug 8, 2006 | 01:32 PM
subhumanzz's Avatar
alright thanks. i just didnt think that i actually needed to remove the pad just the bezel.
