msd ignition installation
Old Aug 14, 2006 | 01:04 AM
slohatch91's Avatar
Default msd ignition installation
has anyone installed a digital6 in their lt1 if so how do you wire it?
Old Aug 14, 2006 | 01:24 AM
buffman's Avatar
should be pretty simple to wire up. Should just be like any MSD box. My friend has a digital 6 in his Lt1 Impala
Old Aug 14, 2006 | 01:27 AM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
I did it around 4 years ago but it was VERY easy, the kit came with the adaptor to attached to the cars ignition..Its basically plug and play and then you just have to mount the ignition box, the popular place to mount it is the area above the drivers side wheel. Its really the only place lol.
Old Aug 14, 2006 | 05:00 AM
LawrenceF's Avatar
It's in the manual that comes with it, have a look for the GM two plug coil diagram. You cut the pink and white wires that go to the coil and splice the MSD in the middle.
Old Aug 14, 2006 | 01:34 PM
396D1SS's Avatar
thunderracing sells a plug and play harness and it took me literally 2 mins to install
