Coolant Crossover
Old Aug 17, 2006 | 03:28 PM
Honda Hunter's Avatar
Default Coolant Crossover
Cant seem to find the thread about it but who knows a good place to get the performance version that uses rubber or braided lines with quick disconect?
Old Aug 17, 2006 | 04:18 PM
the_merv's Avatar
I made my own with brass fittings and high pressure rubber line. It works well, and doesn't take any time to disconnect.
Old Aug 17, 2006 | 04:23 PM
Do you have a parts list? My engine is going in on Saturday (I hope) so I need one fast.
Old Aug 17, 2006 | 04:31 PM
the_merv's Avatar
Got these from Lowes: 3 standard 90 degree fittings, 2 2-inch brass threaded extentions, 2 1/4" fittings for the line, 1 3/8 fitting for the line going to the Radiator, and 1 T joint. Then some 1/4" high pressure line, and a 3 ft piece of 3/8 high pressure line to go to the Radiator, and a couple of small clamps. Draw it out, and you will get the idea. Probably spent $20, and it works a hell of alot better than the factory setup, and is easier to work with.
