Steam Line Design
Old Aug 22, 2006 | 02:02 PM
the_merv's Avatar
Veteran: Air Force
Default Steam Line Design
This is the way I re-built my Steam Line after putting the Heads back on the car. I bypassed the Throttle Body very easily. What was used for the line was 1/4" and 3/8" high-pressure rubber hydraulic line.
Attached Thumbnails Steam Line Design-modified-steam-line.jpg   Steam Line Design-modified-steam-line2.jpg   Steam Line Design-modified-steam-line3.jpg
Old Aug 22, 2006 | 02:54 PM
Honda Hunter's Avatar
What size fittings? Do you have a complete parts list?
Old Aug 22, 2006 | 03:05 PM
the_merv's Avatar
Veteran: Air Force
I was the one that you asked about this before. They are all standard 1/2" fittings, and what you see is all I used. The only thing not pictured is the Teflon Tape, a couple of clamps, and the different size hoses that I used, which were mentioned above. It works very well, and I have not had any problems with it.
Old Aug 22, 2006 | 04:41 PM
dhdenney's Avatar
What was your goal in doing this? Just curious....
Old Aug 22, 2006 | 08:41 PM
the_merv's Avatar
Veteran: Air Force
One was convenience, the Heads went on alot smoother, I removed them while the Engine was still in the car.(My other thread has the pics of that). The other was that if I have to remove the Heads, this will be very easy to break down for removal, and re-installation. It still flows the same rates as the factory line, but a hell of alot easier to work with in my opinion.
That and you buy it on Ebay for $80, I built it for $20. I wanted something different, and it works. I should sell it on Ebay..lol
