Gauging interest, car is getting to me
The car:
1995 Firebird Formula
Engine - 396 LT4
4.030 bore, 3.875 stroke with a callies 4340 racemaster crank
Oliver 5.85 rods, Ross 11:1 nitrous pistons
Childs and Albert heavy duty wrist pins.
Calico coated main, rod and cam bearings
Childs and Albert Zero gap rings with G-2000 top rings
AFR 227cc LT4 cylinder heads, fully CNC machined race ready
-2.10 int. 1.60 ex. Titanium retainers with roller cam springs
Jesel competition series shaft rocker system not the cheaper SS deries. 1.6 ratio
Custom roller cam, .254/.268 at .050 .628/.634
Comp roller lifters
Comp pushrods
LT4 H/D timing chain
Meziere elec. water pump
ATI balancer
ARP head studs
Fel-pro head gaskets
LT4 intake manifold fully ported and matched to the heads, setup to run a mono blade TB, and tapped for pro shot fogger nitrous, and modified to run an MSD distributor
AS&M Monoblade TB
Stefs fabricated aluminum pan
Melling hi volume oil pump
Bosch 42/lb Injectors
Chrome valve covers shaped to allow LT1 alternator, also GM motorsports Pontiac valve covers
MSD Spark plug wires, with wire protectors, and 2 stage colder plugs
Exhaust -
1 7/8 Dynatech headers with removable collectors
custom fabbed y-pipe
Corsa cat-back exhaust system with the premium pro-series tips
Transmission -
Rebuilt t-56 6-speed tranny built to handle around 600 ft/lbs
Rearend -
Moser 9" with 33 spline axles
Strange aluminium casing
3.75 gear ratio
Custom aluminium driveshaft built for 9" to a t-56
Suspension -
BMR Boxed LCA's
UMI adjustable panhard bar
UMI adjustable torgue arm with tunnel brace and driveshaft safety loop
BMR upper panhard relocation bar
Eibach Pro-kit 1.5in lowering springs
Bilstien shocks
New strut mounts on front
These are the things that I can think of so far, unless it says rebuilt, they are all brand new parts. I also think i'm forgetting some other stuff, but not truly significant.
What you pay for this kind of setup?
