While the engine is apart...
Old Aug 25, 2006 | 02:04 PM
Honda Hunter's Avatar
Default While the engine is apart...
As some know I sold my Camaro but kept the engine. The motor only had less than 1500 miles on it but since we had the motor removed and the pan off (since the oil pan doesnt fit) we decided to look over some things to ensure all is perfect before reinstalling the motor and we noticed the rod bearing were showing wear so I ordered more along with some main bearings. Is there anything else we should replace while were in there? The wear was attributed we believe to the amount of fuel that was mixed in the oil. My tune was rich I think.
Old Aug 25, 2006 | 02:17 PM
TurboZ28's Avatar
You'd have to be running rediculously rich to get enough gas to seep past the rings. I'm not even sure if thats possible in a FI car.
Also, if you change your bearings you need to get the crank turned.
I think. lol
Old Aug 25, 2006 | 02:20 PM
I think. lol
Ive seen it happen when people have bad fuel injectors. What are you suggesting? Not having the crank turned, just using standard size bearings. If it's something else now is the time to fix it.
Old Aug 25, 2006 | 02:36 PM
TurboZ28's Avatar
No I meant getting the bearing surfaces on the crank resurfaced. I'm pretty sure you're supposed to when you change your bearings.
Old Aug 25, 2006 | 02:38 PM
Oh. I believe your correct but here's my next question, if I have it resurfaced will the standard size fit?
Old Aug 25, 2006 | 02:42 PM
TurboZ28's Avatar
I would hope so. lol Yeah it will.
Old Aug 25, 2006 | 02:44 PM
Thanks for the heads up. When do people require the +1 +10 and +1X size bearings?
Old Aug 25, 2006 | 02:55 PM
TurboZ28's Avatar
Well.....I have no idea
