problems!!! HELP!!!
Old Aug 26, 2006 | 09:13 PM
SJblackLT-1's Avatar
Default problems!!! HELP!!!
waz up guys. new to this thing. have lt-1 SS and having trouble. when i give the car full throtle the car bauggs and doesnt want to go. jst gets stuck. feels like too much air or fuel but not sure. jst changed opti, spark plug wires, fuel filter, and coil but still no change. if anyone can help i would really appreciate it. thanx!
Old Aug 26, 2006 | 09:27 PM
Honda Hunter's Avatar
If I was you I'd hook it up to the scanner before throwing more parts at it. First be sure the opti was installed correctlly along with the wires. If everything you installed was done right then I'd find out what your o2's are reading. When was the last time they were changed? A scanner (Freescan, Datatmaster, etc) could lead you in the right direction. Also what's your fuel pressure look like?
Old Aug 26, 2006 | 10:25 PM
coo man thanx alot ill check those things out. preciate it.
Old Aug 26, 2006 | 10:45 PM
HBHRacing's Avatar
"bog" is generaly a sign of low fuel volume.
Old Aug 27, 2006 | 11:01 PM
might be my fuel pump thats not pushing enough fuel? coo man thank u appreciate the help ill check it out. have a new fuel pump but wasnt planning to install it till i install the nitrous kit guess gana have to install it sooner. LOL!
