a/c delete pulley?
Old Aug 27, 2006 | 12:00 PM
extremez97's Avatar
Default a/c delete pulley?
do you use the factory size belt or do you need a shorter belt to run this pulley. if it is shorter does anybody know what size works best?
Old Aug 27, 2006 | 12:03 PM
OutlawZ's Avatar
afaik it's a 1LE AC delete pulley and you use the same size belt.. I have a 1LE and it uses the same belt as the standard A/C equipped Z's...
Old Aug 27, 2006 | 12:05 PM
extremez97's Avatar
thankyou very much thats all i needed to know
Old Aug 27, 2006 | 01:19 PM
anaik's Avatar
There were two size pulleys for the A/C, but one size for the delete pulley. This thread gives the info.
http://web.camaross.com/forums/showt...+delete+pulley
