Is this a 'Vette LT1?
Old Aug 30, 2006 | 03:00 PM
Honda Hunter's Avatar
Originally Posted by Steve40th
LT1 Vettes had steel valve covers in 1992, in 93-96 they had composite. The 96 Composite dont have the drip rails for the LT4's due to the Roller Rockers, which were a torque down type roller rocker(made by Crane for GM, with special 10mm studs), 18ft/lbs, as there was no valve train adjustment, just like Fords.
He was told it was a 94 vette engine.
Old Aug 30, 2006 | 03:14 PM
Steve40th's Avatar
I understand, I just went a little further in detail.
And I was correcting you on the valve covers issue.
Old Aug 30, 2006 | 03:24 PM
buffman's Avatar
well if it's aluminum heads its either Y or F body. Cast Heads it's B-car. get a magnet, or look at plug orientation. Al heads have angled plugs, us Cast Head boys dont..
Old Aug 30, 2006 | 03:55 PM
chree's Avatar
Originally Posted by LT1MAN
what kind of vehicle is this in?
It's probably not what you expected... but the family needs the cargo room and I need the hp + 6 speeds :
Curb weight with the V8 should be ~3300lbs. I guess if 'Vettes never came with T56s then I'll have a good idea it's an f-body engine/trans if it has a T56.
From the fleaBay description (editted for LT1 content):
1986/1994 VOLVETTE 740 TURBO WAGON
345 HORSEPOWER CORVETTE ENGINE WITH 14000 MILES
LT1 6 SPEED CORVETTE TRANSMISSION WITH 14000 MILES
EDITOR'S CHOICE AWARD SUPER CHEVY MAGAZINE
$30,000.00 + INVESTED (HAVE RECEIPTS)
118,000 VOLVO 14,000 CORVETTE
STAINLESS TWIN INTAKE PACKAGE W/TWIN K & N'S
INJECTION AIR FOIL
VERY TRICK COMPUTER READS FROM MANIFOLD
I won the auction and I'm not sure if I can negotiate since I can't definitively prove it's not a "Corvette" engine. When asked about veification of the engine mileage the seller's response was "JUST RECEIPT WHERE ENGINE WAS PURCHASED NEW" so I will see that when I pick it up Saturday.
Chris
Old Aug 30, 2006 | 04:01 PM
I disagree on the valve cover issue. Yes it's 93-96 but Im almost sure the 92's got magnesium or something. Anyways Ill look through my books to see if youre correct.
Old Aug 30, 2006 | 04:02 PM
What country you in?
Old Aug 30, 2006 | 04:13 PM
Camaroholic's Avatar
That could be a very cool car. If you do get it, PLEASE clean up the wiring and hoses under the hood. The wiring looks terrible. Car looks clean tho. Wagons are cool - especially if they have 6-speeds in 'em.
I was right. The 92 Vettes got the same valve covers the L98 Vettes got, well I know for sure they didnt get the valve covers shown above.
Old Aug 30, 2006 | 04:24 PM
Note the vette fuel rails.
Old Aug 30, 2006 | 05:18 PM
Armyman2445's Avatar
It could be an Impala LT1 was has les HP than an F-body LT1.
Old Aug 30, 2006 | 06:53 PM
buffman's Avatar
I'd be willing to bet it's an F-body LT1. Check the waterpump design and that will at least tell u if it's an F or Y car and not a Bcar LT1
Old Aug 30, 2006 | 08:18 PM
  #32
cyamaha2007's Avatar
cant he just pop the knock module out of the computer and have the #s run i dunno know if it will work i just thought of it, looks like a prety clean hybrid though good luck.
Old Aug 30, 2006 | 08:23 PM
  #33
Built LT1's Avatar
Something isnt right. The valve covers are wrong, the fuel rails are wrong (explainable), The accessory setup is wrong (explainable), and iron heads WTF? I dont think its a Vette motor at all. Drop the pan.
I had an LT1 Vette. Those valve covers are most definately not the one's that come on a Vette.
Old Aug 30, 2006 | 08:28 PM
  #34
Any ecm couldve been used.
Old Aug 30, 2006 | 11:18 PM
  #35
buffman's Avatar
knock module will all be the same save for a 96 LT4
Old Aug 31, 2006 | 02:34 PM
  #36
chree's Avatar
I hope the car is as nice as it looks (the engine bay definitely needs to be cleaned up - which will give me a good chance to check for problems).
This is the what the engine bay should look like: (Yellowbrick's LT4 Volvo)
Old Aug 31, 2006 | 03:07 PM
  #37
Built LT1's Avatar
All this speculation could be resolved if someone would just look at the serial numbers on the engine.
A dealer could tell you in minutes where it came from.
Old Aug 31, 2006 | 03:14 PM
  #38
buffman's Avatar
I've got another vote that's it's an F-body unit. Note the location of the fuel pressure regulator..
Old Aug 31, 2006 | 03:18 PM
  #39
That's a clean LT4 install.
