Bang for the buck
Old Aug 30, 2006 | 07:32 PM
Kanes2413's Avatar
Default Bang for the buck
i have a 93 lt1 t/a first off with a custom turbo from OFI ,t67 with tubular headers and im thinking i need a rebuild on the lt1. I want to make the most power possible with a forged engine and good h/c setup to go along. Help me buy telling me what kind of rebuild i should look into that i can gain the most power and reliability with. i have about 5-8000k to spend on the whole rebuild but i dont wanna buy a new shortblock thats the only thing tell me some suggestions?
Old Aug 30, 2006 | 07:46 PM
IllusionalTA's Avatar
well w/ a budget like that.. i'd say a 355 rebuild w/ a good crank,rod's and some nice piston's will be a good idea.. As far as heads go.. a set of ported lt1 casting's along w/ a nice turbo cam should do ya right.. You have to figure out what your ulitmate goal is.. that will then determine which way you go..
Old Aug 30, 2006 | 09:50 PM
1SLO6's Avatar
drop the compression add more stroke a good nice cam and head port a efficent drivetrain and hello 10's or even 9's. try not to go to radical or u can run into bigger problems with intake efficency.
Old Aug 30, 2006 | 11:44 PM
Kanes2413's Avatar
im hoping for a 650 to 700 hp street car well my budget is more i just dont want people saying drop an ls7 go huge on h/c i just wanting something with that add big power but reliablity so i was seeing suggestions what others did
Old Sep 1, 2006 | 07:16 AM
NOSARMD's Avatar
I agree 100%. Don't skimp on the bottom end parts. You could do something like this. I was reading a post of that bottom end with stock heads make 520/468@10psi.
-Callies Dragonslayer 3.480 Crankshaft
-Compstar Connecting Rods
-Diamond Pistons
-Total Seal AP Rings
Originally Posted by IllusionalTA
.....i'd say a 355 rebuild w/ a good crank,rod's and some nice piston's will be a good idea..
