ASM Monoblade on a SR 396
i might be a few off on the duration but its around there somewhere.
"BRETTINATOR" That cam looks pretty healthy and from what I'v been told by others, that area Mechanical Roller cam works very well for Strokers. I was looking at going that route with a 256/260 on a 106 or 108 LSA (auto car, need that mid range). But still undecided... Rock on at the drags and keep us posted.....
I just do not understand all this hole drilling going on!
I would crack the blades untill you have nearly zero IAC hot in 'p' and 'n'. then readjust the TPS to read .60-.65v.
the biggest reason for problems is the ultra short intake runnings.
BTW I am thinking Jims car will 60ft 1.4xx next time out on my street tires
Dude 1.4 on street tires???? that's crazy...what ya got up in that thang...a HEMI?
so basicly just set it up to idle at 0-5 IAC counts by opening the blade. then shut the car off and restart it to make sure it is still there. this needs to be done with the car good and hot.
Once you have that done reset the TPS to .60-.65v. with the car off. turn the car off then back on again a few times and make sure it stayed.
Also make sure the Ports under the TB is blocked off and not going to the PCV or any thing else.
BTW last time we had Jimbobs car out we were running out of fuel(fuel pump dieing) on my M/T ET Street DRs 275/49-17s and yanking the wheels to 1.51 60fts
She was falling on her face well before the 60ft. His car leaves WAY harder then mine!
She was falling on her face well before the 60ft. His car leaves WAY harder then mine!The Best V8 Stories One Small Block at Time
My TPIs MONO we are putting on Jimbobs car also does not have the side ports
Yes if you have some thing going into that hole it feeds the IAC passages directly even if the IAC is closed.
Now it is open to the plenum. not a big deal but I would close it off and run vents to a vacuum pump
Blk97Z I basically gave LME my goals on all-motor and they worked with CamMotions to come up with the right combo. I really wanted a lower lsa but with the 12:5:1 compression he wanted to keep the car pump gas streetable.
10 rwhp is what I saw also. I bought mine in kit form from Reher & Morrison Racing Engines in Arlington TX. Only had to buy one bolt to install it. You will run richer with the pump, I had to lean mine 5% when I put the belt on the first time. 5 more rwhp right away, the other five after I leaned it back down.
Good luck, Ed
Good luck, Ed
