Help!
Old Sep 6, 2006 | 11:03 PM
donkey mule's Avatar
Default Help!
What are the most heat resistant plug wires that you all are using? I have long tubes on my 95 TA and have burnt wires on several occasions. I even burnt one with an insul tube on it! I need some help and some opinions!
Old Sep 6, 2006 | 11:36 PM
-PEPE-'s Avatar
well I'm now running MSD 8.5mm with Russell boot sleeves not over the plugs but actually where they get close to touching the primaries and it works great. When I had the LTCC I ran 10mm Magnecore wires, which for $175 they better be heat resistant, those puppies worked great too, but I'm back to running an opti now so switched.
Old Sep 7, 2006 | 05:27 PM
Thanks for the advise, I might have to try the msd's out.
Old Sep 7, 2006 | 09:41 PM
the_merv's Avatar
What LT's do you have to where you are burning them up. I don't have that problem..
