can anyone make sense of this?
Old Sep 8, 2006 | 05:15 PM
edlt1's Avatar
Default can anyone make sense of this?
I took my car for a test run. I live on a dirt road. I stepped on it redlining first gear spinning the tires. All good untill the car didn't shift and was bouncing of rev limiter like I was driving a stick.
Is there any reason why the trans wouldn't have shifted?
Old Sep 8, 2006 | 05:50 PM
87Lt1Monte's Avatar
i know it sounds dumb but did u check the trans fluid..? How old is the transmission? Does it shift to second when ur just bs'n? was it in DRIVE?
Old Sep 9, 2006 | 08:41 AM
edlt1's Avatar
yeah in drive. I'll check the fuild. The trans only has like 8,000 miles on it
Old Sep 9, 2006 | 08:50 AM
the_merv's Avatar
Veteran: Air Force
You need a re-tune for them gears. Mine did the same thing on the track after we got the gears in it, and we just adjusted the shift points. No problems now..
Old Sep 9, 2006 | 08:52 AM
edlt1's Avatar
I just had it tuned
Old Sep 9, 2006 | 09:04 AM
the_merv's Avatar
Veteran: Air Force
Yea, you need it re-tuned again. The shift points have to be adjusted. Mine did the same thing.
