surging
Old Sep 8, 2006 | 09:04 PM
Revelation Z28's Avatar
Default surging
my car started surging on idle today. itll idle at 1000rpm normally then either when i pump the brakes a little bit, or put the clutch in to go into 1st, itll go up to 1500rpm then back down. even sitting at a light itll do it. i noticed no vacuum leaks or anything. im thinking the plug wires as they are the stockers. new opti and new plugs. and new FPR. it MAY be the fuel pump, but i doubt it since it starts great and runs hard. #7 cyl plug wire is pulled about 1-2mm out of the boot where some of the white "rope" insulation is showing.
