cc503 cam requirements
so heres what i wanna do. either a cc305 or 503 cam with stock heads.
once i save up after that install is done ill ship my heads to elliot and have him port mine.
now heres the question:
will stock lt4 valve springs be ok to use with either cam? I am not sure of the lift on them but have read that they may work. What about a new timing chain set? Is that absolutely necessary with this cam? I know it'll be revvin up to 6k and i dont want **** to break. basically i just wanna get what i absolutely need for this cam to work, not every damn comp cam bolton.
plus, i dont wanna be spendin ishloads of money on this cam either. Im gonna install it myself to keep $ down
You are going to end up buying some stuff twice.
Suggestion: Call Lloyd Elliott, discuss what you goals are and all the rest of the stuff you'll be using, like gears, trans, headers, etc. You may possibly be able to buy springs just once. Same for the cam. I'm not convinced your current plan is the best and least expensive one.
My $.02
I am also going to be putting the 503 in my car soon. I went with cc 918 springs, cc promag 1.6 rr's, cc 4130 chromemoly push rods, GM guide plates, and OEM lifters(you probly don't need these. I'm just doing it for piece of mind). When it comes to your valve train, it's best to not cheap out.
Just my .02
You ain't the expert here, emerica. No offense intended; you are not alone.
A difficult task is to admit to ourselves that we are not experts at such things as choosing cams and valvetrain parts, let alone engine design. I have been watching this stuff for years, and I will say that a car owners' egos have gotten in the way of a large number of modifications. IOW, they made poor choices for parts and systems because they thought they knew more than the pros, and more than they really did know themselves.
As for gettng to 350 rwhp with usable torque in the range you operate the engine, it has been done, but it took a bunch of valvetrain parts in addition to cam and springs to do it.
Free advice, like mine here on the forum, is worth just what you paid for it. I won't burden you with any more. I think your mind is made up. Good luck, and let us all know how it works out.
So Im going to take your advice. Im gonna call a few experts who have been workin on ltx/lsx engines for a while. They are the true experts.
Thanks again for your advice, I think im headin in the correct direction now
