Convince me to buy longtubes
Old Sep 14, 2006 | 01:13 PM
Taubr Unit's Avatar
Default Convince me to buy longtubes
i got mid RK sport headers. They do come down pretty far, t he collector is pretty much under the car. Kinda like shorty longtubes, if that makes sence, lol. Got them with a ORY pipe, bullit muffler where the cat was then dumped. So its deff. free flowing. Now convince me ill still gain with LT's. I can get coated Hooker's for $419.00. Now with the LT's, ill have 2 bullit mufflers bolted to the flanges then dumped. Its a strip car only basically, so im not gonna run a y-pipe. So will i still see a gain with the LT set up vs. my RK Sport set-up? What kind of power range/gain will i see switchin to LT's.
Old Sep 14, 2006 | 01:45 PM
MrCadillac's Avatar
actually, you want the pipes to be a certain length for optuimum power. the trick is, take regular paint/nail polish, and put a steddy line on the inter pipe. go drive around and let it get nice and hot. right where the paint just becomes discolored(twards the cat will be black, at the rear end will still be white), thats an old racers trick about where to end the pipe/put the muffler and dump/ add an H pipe. It works pretty well.
anyways. Long tubes over mid lengths, not a huge difference, but you likely will see a gain.
Old Sep 14, 2006 | 01:46 PM
MrCadillac's Avatar
https://ls1tech.com/forums/lt1-lt4-modifications/569345-convince-me-i-need-long-tube-headers.html
Interesting... hmmm....
Old Sep 14, 2006 | 01:53 PM
fordeater's Avatar
long tubes are the way to go
Old Sep 14, 2006 | 02:36 PM
skatinjay27's Avatar
the rk sport mid and good mids and basically the same design as the asm mids which flow just as good a lts.so its you call i wouldnt spend the 500 extra bux for a couple extra hp if any. also the rk and asm mids have 1 3/4 primaries just like most LTs
Old Sep 14, 2006 | 02:45 PM
96lt1m6's Avatar
long tubes work!plain and simple,the power gain from the mids you have and the mac mids will not be a huge gain possibly 10hp
Old Sep 14, 2006 | 02:56 PM
Bad Dad's Avatar
IMO you don't have the mods to justify going to a LT.
Old Sep 14, 2006 | 03:26 PM
Taubr Unit's Avatar
really nobody has the "mods" doing LT's. Theres people putting LT's on bone stock cars and you think they got the "mods" for LT's?! And what makes a car qualifyed for LT's?
Old Sep 14, 2006 | 03:39 PM
Captainofiron's Avatar
Buy the LTs or I will steal your car.
Just kidding.
I bought some FLP LTs a while ago. I love those things. It changed the exhaust note up and made my car sound alot meaner than before. I had thought it sounded ok before but after the LTs man it sounds good. I felt a huge difference over my stock manifolds. I had cleaned up the entry ports of the manifolds with a carbide porting tool so I assume that they flowed alittle better than stock.
I dont know how much of a power gain I achieved, but now I just need to hit the throttle just a bit and the tail will go waggin. The engine wants to keep going once I get up close to 5K rpms.
Old Sep 14, 2006 | 03:52 PM
slowmofo's Avatar
convince you??
13.77 to 12.9--mph 100.3 to 105.8 Added a CAI, and LT's, mods before were 3500 stall and 3.42 gears. No tune
Old Sep 14, 2006 | 03:53 PM
Bad Dad's Avatar
Cam, heads...
IF you didn't have headers on the car already I'd definately
reccomend LT's.
I switched from a shorty to a LT with no other mods.
Picked up .001 and .1 MPH. Not worth it.
Old Sep 14, 2006 | 04:55 PM
omaha stylee's Avatar
Originally Posted by slowmofo
convince you??
was this with an LT1 or a LS1 because they are two totally different realms as far as head flow.... Not trying to call bullshit or be a dick for that manner but I highly highly doubt that out of a bone stock LT1 with a stall LT's CAI and 3.42's unless you have a major factory freak car....... if it is an LS1 I believe it..... I have seen what LS1's can do with just bolt ons.... wish the LT1's heads flowed so well stock
Old Sep 14, 2006 | 04:56 PM
Speed Density's Avatar
hashtagBMW
Dont listen to SLOWMOFO, he speaks the truth. Longtubes suck. Stay Mids.
If you have a V8 of any make, you must have LTs!
Old Sep 14, 2006 | 04:58 PM
Originally Posted by Bad Dad
Cam, heads...
reccomend LT's.
agreed if you have stock manifolds go LT's without a doubt unless the car is lowered...... goiung from shorty/mids to LT's I wouldn't waste the money unless you are going with aftermarket or ported stocker heads and if you are getting the heads obviously you are going to get a cam.....
Old Sep 14, 2006 | 05:33 PM
slowmofo's Avatar
Lt1...my Bolt on ls1 car runs 12.5's with smaller gears, and smaller stall
My friends bolt on LT1 ran 12.7's, with a th350, full suspension (hals on all 4)and a 12 bolt. N/A and 11.5's on the jug.
Then he added a small nitrous cam, gasket matched the heads removed a bunch of weight and has run a best of 11.8 n/a, and 10.9 on a 150 shot.
Lt1s are faster then most think
Old Sep 14, 2006 | 09:13 PM
DroppedM6Z's Avatar
2" drop on my 95 and i'm careful....they dont ever touch really. You wont see Tq like mine with mids.....
Old Sep 14, 2006 | 09:28 PM
I didn't mean to doubt you but by how you put it before it sounded like there was no suspension work and stock trans and rearend... i'm gonna guess that he has the car tuned as well and is on a sticky tire
Old Sep 14, 2006 | 09:44 PM
urbanhunter44's Avatar
12.9@105 dumped LTs, cai, tires, couple suspension pieces.
Old Sep 14, 2006 | 10:28 PM
Taubr Unit's Avatar
well im gonna keep my mids and spend the $450 on a cam. thanks for the input. Ill see a better power gain with mids and a cam vs. stock everything and LT's now i need to decide on a cam. Here we go again.
Old Sep 15, 2006 | 04:21 AM
slowmofo's Avatar
sticky tire yes, but cars still on the stock tune and runs real rich. He runs a dry kit so he doesn't care.
