oil pump
IMO a stock volume is good but talk to the guy doing the machining do things his way otherwise if something gets messed up he will blame your decision.
If you go with HV I would strongly encourage you to upgrade the oilpan. The stock setup is good with stock stroke and stock pump but start moving more oil combined with losing the windage tray to the longer stroke crank and things get scary.
