TH-350 shifter?
Old Aug 20, 2002 | 06:28 PM
93LT1Z's Avatar
Default TH-350 shifter?
I just picked up a TH350 to replace the 6 speed in my 93 Z28. Which shifter is prefered for use with the 93-96 centerconsole? I have seen the Turbo-cheetah installed but not others. I have a reverse manual valvebody in the trans. If I remember correctly I need to get a different trans crossmember to use the 350, but I would NOT if I was using a TH-400. I already have a madman torque arm set up so there won't be issues with that. I will also need a new flywheel and flexplate ...any suggestions? The car makes ~ 440 rwhp N/A and then there is a 200 hp TNT kit.
Old Aug 23, 2002 | 06:18 PM
onebad96T/A's Avatar
Default Re: TH-350 ?
I used a Hurst Quarter stick in my T/A but it requires alot of cutting on the console so i went and bought a used console at a junk yard for 25 bucks. And for the cross member i bought a kit that comes with a new output shaft and a 2" spacer that goes in between the case and the tail housing and it lets me use the stock cross member and lets the speedo work, it only cost me like 150$ for the kit and it works like charm. I also used my stock fly wheel and i am also using a Spohn Torque Arm. And the TH-350 and TH-400 are the same length i believe.
Old Aug 23, 2002 | 06:33 PM
pbperformance's Avatar
what are you going to do with the t-56 ?
Old Aug 27, 2002 | 06:56 PM
lt1z93's Avatar
Probably sell it. It has 93 ratios.
Old Aug 27, 2002 | 06:57 PM
lt1z93's Avatar
who makes the kit you are using?
Old Aug 28, 2002 | 05:41 PM
My local transmission builder got this kit from a company called ATC/DGI they are in Florence AL and the part # is 7-35B and its called a Teckpak SwitchKit its acrually for 700R4 and 4L60E's also here is ther phone # 256-767-3141
