changing from speed density to OBD1?
Clyde
The swap is worth it now that I look back, although at the time it was a pain (mostly due to the fact that I didnt have the GM wiring schematics).
I used:
95 PCM
95 engine wiring harness
heated O2's
95 MAF
95+ Opti and related stuff (harness)
There were about 5 wires that were different between the harnesses (i cut and spliced at the firewall). They were the biggest problem for me since I didnt have the wiring schematics for a while. Stuff like AC (which I took out), skip shift (which 93 dont have obviously), and a couple other difference between the years.
If you have the schematics, it wont be that bad. Well worth it now that I can use LT1 Edit.
Let me know if you have any other questions
Jason
