Is the '94 model differential the same as the '95 model?
Old Jan 7, 2003 | 02:33 PM
Kevin Winstead's Avatar
Default Is the '94 model differential the same as the '95 model?
Is the '94 model differential the same as the '95 model? I've got a '94 model Formula and a '95 gearset that I'd like to put in it.
Thanks!
Kevin
Old Jan 8, 2003 | 12:16 AM
CW 99 Z's Avatar
Default Re: Help with a differential
Should be the same Kevin. Just as long as thier both the same series carrier.
Old Jan 9, 2003 | 12:28 AM
Thanks for the info. I should have asked about the ABS reluctor. Is the '95 reluctor compatible with my '94 rearend housing?
Thanks again,
Kevin
Old Jan 9, 2003 | 02:50 AM
CW 99 Z's Avatar
As far as I know there werent any changes in the rears. As long as thier both the same type IE being TCS or non TCS you shouldnt have a problem. I installed a 96 diff and gears in my 93 and it worked fine. Now I got a Q for you <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Can I spray a hundred shot with a standard TCI 3500?
Old Jan 10, 2003 | 01:04 PM
CW,
I've sprayed mine with a 250 shot with no problems. You won't have any problems with a 100 shot.
Take Care,
Kevin
Old Jan 12, 2003 | 01:35 AM
CW 99 Z's Avatar
Thanks Kevin. Just what I needed to hear. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
